When are you going to stop trotting out this irresponsible and misleading advice??
Maybe when those who can't seem to see back beyond the current edition of BS7671 accept that a new edition of the Wiring Regs. which introduces new (non-mandatory) requirements doesn't automatically render any installation done to an earlier version dangerous or somehow in desperate need of replacement.
It is nearly 4 years since the requirement to protect ALL sockets was introduced,
As I said - A recent change.
but even so, 30mA protection for sockets is hardly a recent idea. It was a requirement to protect all sockets which may supply equipment for use outdoors almost 20 years ago.
Yes, but as you've just noted, not for
all sockets. And again, if you would put this into perspective, while I'm not saying that a 30mA RCD doesn't provide additional protection, that doesn't mean that even a socket used for outdoor equipment is
unsafe without it.
The 30mA RCD requirement (for external use) was introduced with the 16th edition in 1992. That's
1992, yet to hear the response of some people to lack of an RCD on this circuit or that circuit you'd think they were condemning something from
1892 when there was much still to be discovered about basic protective measures.
What standard do you propose the electrician works to then if not the current edition of BS7671?
As I said, that's the problem in this country - Finding anyone from the "normal" electrical installation industry who can actually look at things in a reasonable manner and put things into perspective, and not just trot out what BS7671 says at this moment.
One has only to look through some recent posts on this forum to see the response of some people to running as much as new switch drop in wall without RCD-protecting the circuit. Yet these same people were no doubt installing just such cables a mere 4 years ago and declaring them to be perfectly safe, and not in any way suggesting that it would be "good practice" to add an RCD anyway.
If there's no bonding in the house should this be ignored too because it didn't used to be required?
Well, there have been posts on here suggesting
not to bond things which older editions of the Wiring Regs. always stipulated
must be bonded, so I'm not sure that's a good example.
