RCBO wiring
12 Feb 2011
Bedfordshire
Hi
Can you tell my how to connect RCBO in consumer unit ?I've got some thin and cream wire, don't know what to do with him :(
regards
You're posting in the "Electrics outside the U.K." area, but your profile says you're in the U.K. Assuming this is a British device.......
It's a functional earth and should be connected to the earth bar.
I believe only the types which use electronic amplifiers in them need to have a functional earth wire, it is to do with the supply voltage collapsing in the event of a fault. Single module RCBOs are usually electronic.
