Re-attaching pressure sensitive pipes to divertor valve
11 Feb 2008
Cheshire
Hi ppl,
I have changed the diaphragm inside the divertor valve in my Halstead Ace boiler, im having major problems re-attaching the pressure sensitive pipes back into the valve.
Every time i try, the pipes look offset slightly as they slot in and when i put the clips on and start the water supply, they begin to leak.
Help needed, or it will be a cold night!!
You have to dry them and add KY jelly to both male and female parts and then they will slide in smoothly.
