I cant see the point of checking the insualtion via the internal wall, or even removing it at this stage .
The internal dampness is a symptom, not a cause, and its not certain if that even relates to the insulation or the ties - there are more cracks than damp patches.
Likewise for the render. That has been most probably caused to fail by something else - either the wall panel (sections of the wall), by the materials - blocks, bricks or mortar, or possibly ties. And the cracks are external, which implies a problem specific to the external leaf. This in turn could mean that moisture is a contributing factor - either on its own or causing a reaction in the wall materials
So the cracking is not "render failure", and the render should not be repaired until the actual cause has been identified and remedied
I'd opt for more investigation of the external leaf and material samples. A thermograhic survey (after extensive rain) may show up areas for further investigation, or show a pattern of potential defects.
The best thing may be to engage the services of an expert in building pathology, rather than a run-of-the-mill surveyor or engineer.
