Rebar in Foundation and Pillars.
27 Dec 2011
Essex
Curious to find out as seen builders dropping a rebar frame of 10mm in foundation next door.
Will the rebar not rust in about 15-20 years or maybe a bit longer once PH drops in concrete.
Also when the walls are being build in blocks,they are using a pillar with concrete inside on corners with rebars in it,but not tying in the blocks. I have never seen anything like this. Is this new method of construction.
Normally the corner the blocks overlap the one below. Again just curious to find as never seen anything like this in UK.
No. Unfortunately the best i could hear is swear words in English. Most workforce are from Romania and possibly Africa.
Well that ya go. :rolleyes:
Next question, is this a legitimate extension with proper plans and stuff?
