I have an old stud wall which I need to get in to in order that I can install a light switch. The current wall is a couple of inches thick, consists of a timber frame with horizontal wooden slats covered in a hairy bonding material, and then a thin top smooth skim.
So I'm going to need to cut a section out about half way up to to the ceiling in order that I can tread a cable inside the wall. The wall will be tiled, so I am a bit concerned about just covering the hole up with plasterboard as when it comes to replacing tiles it will bring the board off with it.
Could I use another type of board instead, such as plyboard or MDF?
