Hi there, I need some help with my DIY. My semi detached house is a new build hence the inner shell plasterboards and stud walls 
My kitchen is of the size 2580 X 2470 mm.
The current worktop is laid out in a u-shape pattern. Hence the base cabinets are in that shape. The Wall cabinets are only on 1 single wall. The reason for this I guess is because the additional wall they could have used is just simply a stud wall that partitions the lounge from the kitchen.
I have tapped along this stud wall and it seems pretty much hollow with not much vertical support!
I would like to place a couple of wall cabinets on this wall (i.e. part of the 2470mm stud wall). This I presume (in theory) will mean
1) Take off the plaster board on the kitchen side of the stud wall
2) Reinforce the stud wall with extra timber…. To bear the weight of the wall cabinets
Questions
1) Assuming I am doing this myself, how do I reinforce this stud wall? Will it have to be vertical Timbers going from floor to ceiling? And then horizontal timber joining the vertical ones…And then putting plasterboard back up?
2) Assuming I was going to get someone to do the above mentioned wall (no tiling/painting); what is a reasonable price for the job?
3) Thinking of doing my bathroom as well. It is currently 60% tiled on plasterboards. Will it be a quicker job to just pull all the walls down or go via the process of taking the tiles off?
Cooa99
Questions
Cooa99
