Recommend me a water heater
18 Aug 2008
Devon
I need a water heater to feed a shower, basin and sink. There is good mains pressure and I'm not restricted by space. It can be an under sink heater or be fitted in a cupboard of it's own out of sight. My budget is about £200 and I need one that is good value and will last a while, preferably with engineer call out option (if there is one).
I have a thermostatic mixer shower at the moment, will this conflict with any electric water heater I might have? Also I like having good hot water pressure, will I still get it?
Champagne ideas., beer money....
You could just about fit a 12kw Powerstream instantaneous heater within your budget but the flow rate will be carp. For the kind of size storage heater you'll need to run an acceptable shower you'll need closer to £500
Thanks, what about this then http://www.ebay.co.uk/itm/Redring-12kW-Powerstream-Instant-Water-Heater-RP12-45793202-/221192058169
It says Allows the supply of up to two basins or one basin and one
shower with instant hot water
Water outlet via existing tap or mixer (especially suitable via spray tap)
So will this work with a mixer shower ?This is a one bedroom flat so it shouldn't be a problem if it only supplies hot water to one appliance at a time, you reckon pressure will be **** though?
Try standing under a shower at just under 5 litres per minute (NOT an electric shower) and see just how shit is.
Do you suggest I change the mixer to an electric shower heater and have a separate water heater for the basin and sink ?
I think the suggestion is to up your budget.
Or maybe post this on rated people or suchlike. :lol:
Rated people :lol: yeah get quoted £1500 to fit something that takes 2 hours for them to do
http://www.screwfix.com/p/ariston-europrisma-2kw-15litre-undersink-water-heater/60922
Would this supply a basin and sink with good pressure?
Also can someone explain to me the different kilowatt ratings, how does this work ?
A shower less than two minutes long? Very generous ;).
More likely, spend £199.50 on an even crapper version of what you are asking for here :lol:
Not that I think that is possible.
Ok but clearly I'm open to suggestions. If the shower mixer is replaced with an electric one and an undersink water heater supplies the basin and sink I'm hoping this will be suitable and want to get advice on the best configuration
This is for the basin and sink only, if you re-read
More kW means more hot water per minute.
Bare minimum shower through a regular head would be about 8 l/minute. To do that instantly would mean nearly 20kW.
Electric showers work by using restrictive shower heads to give the illusion (thinly veiled) of a shower at about 4 l/min.
To get more water with less kW you need storage, but that just offsets the reduced energy input.
This is assuming a 35 degree temperature rise in water - which again is a bit crap.
Hence Muggles nicking my phrase "champagne ideas, beers money". - Muggles - it has been duly noted ;).
The only way I can think of getting your idea to work would be to change the shower head on your mixer shower for a spare one from an 8kW electric shower, but frankly i would rather smell than use it.
Post overlaps.
The Ariston unit will be fine for basins and sink, given the lesser of multiple evils.
Do you know what loadings your electrics can take? With this set up you are pulling 65 amps just for water heating.
What about space heating, cooking, lights, TV's etc.,?
