Redfyre centramatic problem
The oil control valve is passing when closed.
Thanks Oilhead for the prompt response.
There's a valve before and after the reservoir. I'm guessing the one after the reservoir.
Can it be tested - maybe disconnect from the pot inlet and leave it to see if its weeping? If its faulty Terrywookfit previously said they are generally available
Isolate the fuel flow into the control valve, you can then take off the top. turn the fuel back on and check the float level. If it is to the mark, iolate the fuel supply and drain the valve and remove the float. You will then be able to clean up the pin and the seat of the outlet. When reassembling, check the float operation and latching mechanism, then turn the fuel back on and check the level when it latches off, check for seepage.
Brilliant. Thanks so much.
