Today finally got round to replacing my old Redring California - it had a faulty heating control switch. Very limited with wires/pipes and tried to get a like for like replacement - nothing doing so I got the model in the title here.
Supposed to easyfit and after a 4 hour struggle got it done. Fired it up, no leaks and it gets hot. Job done or so I thought.
The shower head continued to leak a little water and on closely listenting to the shower case I could hear that it was still on. Checked the instructions again, took the cover off made sure everything was seated correctly, and it was and so tried again, same result.
On one attempt I put the cover up but left out the screws and it started and stopped as it should and no leaks from the shower head.
Put the cover screws back in and pressed on the outer cover and you could hear the unit starting up again - without the need for pressing the switch and there was a slight water leak from the shower head.
Don't think I've done anything wrong with the install so is this just a faulty on/off switch or is there something else you've heard about regarding this sort of shower?
Thanks in advance
Thanks in advance
