We’re having leaks though the cement fillet flashing between the roof and parapet walls on our victorian end-of-terrace. As such, we want to replace the flashing with lead whilst at the same time patching up the top of the parapet walls themselves (brick-on-edge coping) as many of the bricks are pretty knackered along with gaps in the pointing and plants growing!
We’re getting 3 quotes but they’re all suggesting different solutions and I’m struggling to work out what is worth spending the money on.
For the flashing:
For the parapet wall repair:
The last guys argument for the render bead was that the step flashing wasn’t really worth it on the old walls and the repointed joints are likely to drop out.
My main questions are:
Thanks,
David
For the flashing:
- step flashing chased and wedged into the brickwork joints.
- lead fixed with stainless steel render bead and render to corbelling.
- remove plant growth, minor re-pointing and treat with Thompson’s Water Seal.
- render over the entire top of the wall to the corbelling.
- twice weathered coping stones along top.
- Does step flashing work on old bricks and parapet walls?
- Is there any point in putting Water Seal on the top of the old brick-on-edge coping?
- Will the render simply crack on top of the parapet wall if used as an alternative to proper coping? They said they would guarantee the whole lot for 10 years.
- Does anyone ever use metal coping on these kind of parapet walls? Seems to me like it would be ideal, as quick and light to install.
Thanks,
David
