- Joined
- 14 Dec 2017
- Messages
- 2
- Reaction score
- 0
- Country
Hi guys
I have a water system installed as below. This is fed by pump attached to a reservoir also in the basement. The water is run through a Reliance 3 bar pressure reducing valve with a 4.75 bar pressure release.
When the system was about 3 years old water from the pressure release outlet started dripping and this only seems to happen when the hot water is is being heated.
I have tried replacing the pressure release valve of the multibloc but the problem remains.
I have also checked that the water is not actually coming from the tank pressure release outlet.
I'm now thinking about replacing the whole multibloc now but I wanted to see if you guys would recommend anything else.
Cheers
Darren
Cheers
Darren
