- Joined
- 2 Sep 2007
- Messages
- 3
- Reaction score
- 0
- Country
Well I have a good look through the search facility and cannot find anything that meets my needs.
Just to introduce myself, I am an Englishman living in a 5th floor flat in Moscow, Russia. You might also be interested to know that when you buy a new flat in Moscow, you receive it 'core & shell'. i.e. it is empty and you are responsible for fitting all the electrics, heating, sanitary ware, flooring, plaster...... the whole 9 yards. This results in differing standards of renovation work and as in my case you spend a lot of time correcting the results of bad workers.
I have a bathroom sink that slopes towards the wall catching water that I need to remount and I have a toilet that for some reason is not against the back wall resulting in very little leg room for anyone over 5'.
Plus, despite me tightening the two retaining bolts on a regular basis, it always seems to become loose again within a couple of weeks.
So, I want to try to move the toilet back about 6 inches and secure it. I'm hoping that it is mounted onto the ceramic floor tiles and that they're not cut out around the unit itself. It does look like the toilet sits upon them though.
So, is it a straight forward drill though the ceramic tiles into the concrete floor below and use suitable rawl plugs and bolts to secure the unit into place? And, is it necessary or usual to seal around the base with silicon for effect and stability?
I have a flexible water pipe feed to the flush and a concertina connection between the toilet and the downpipe so I do not need to do any plumbing for the short distance move I propose.
Thanks in advance for any replies. - I will be flushed.
