Remote floodlight?
12 Jul 2009
Yorkshire
Is there such a thing as a remote security floodlight?
I'm wanting to fit an exterior floodlight the the top front of my garage pointing at the drive but i don't want a PIR as there's an alley next to the drive so the light will go on everytime some1 walks there dog down there.
I'm wanting 1 with a remote fob so i can switch it on when i'm at the bottom of the drive before reversing up (20 metres) and for when i'm walking to the garage to get the car.
Idealy 1 of these with a 60second delay would be ideal
any ideas?
Think there is actually, you might find something on a security website.
You can get remote control plug in adapters which can be used to supply the light but would not be suitable outside
Can you not mount a separate PIR low down so that it looks at your driveway but not over the fence or whatever into the alley?
most PIR's come with a stick on "mask" to limit it's sight lines.. it may take a bit of fiddling but you can mask out the alleyway but still keep the drive in sight of the PIR..
Induction loops to sence the car are cheap, but require embedding in the drive.
Infrared beems are also very cheap these days, and will require the car to drive through them.
Remote contolled boards in IP enclosures are also available, typically a remote fop with 4 buttons and the PCB board has 4 relay outputs, switchable internally during setup for pulsed or latching output.
You really just need to google, and look at security web sites in particular.
