    Dismiss Notice
Removal of bath hot water tap
Discussion in 'Plumbing and Central Heating' started by jtmk, 5 Oct 2017.
Tags:
  1. jtmk
    jtmk
    16 Aug 2010
    113
    Thanks Received:
    3
    Buckinghamshire
    Country:
    Hi, can anyone tell me how I remove the following hot water tap please? I've taken the screw out but the part you turn for hot water won't pull away from the rest.
  2. Sponsored Links
  3. just pumps
    just pumps
    24 May 2016
    3,059
    Thanks Received:
    517
    Country:
    Think of it as a nut, spanner on the large hexagon and the whole cartridge will unscrew.
    • Like Like x 1
  4. What is your eventual goal,knowing what you want to achieve will get better replies.
    • Like Like x 1
  5. Madrab
    Madrab
    4 Oct 2012
    8,554
    Thanks Received:
    2,479
    East Renfrewshire
    Country:
    Is it the hot tap head on the left you want to remove or the diverter in the centre? If it's the former, then and adjustable spanner behind the tap cross head and tapping it with a hammer should knock it off the splines.
  6. jtmk
    jtmk
    16 Aug 2010
    113
    Thanks Received:
    3
    Buckinghamshire
    Country:
    Sorry, I should have said they I'm trying to fix a leak from the hot tap.
  7. jtmk
    jtmk
    16 Aug 2010
    113
    Thanks Received:
    3
    Buckinghamshire
    Country:
    I can unscrew the large hexagonal nut behind the hot tap head that connects to the pipe that comes out of hole in the bath, but I thought the issue with leaking taps was behind the tap head itself? I cannot remove the tap head after unscrewing it.
  8. Sponsored Links
  9. oldbuffer
    oldbuffer
    6 May 2010
    1,491
    Thanks Received:
    559
    London
    Country:
    1. The handle is fitted to the spindle (which you can't see) on splines, and fastened in place with a screw. Provided you've taken the screw out of the tap handle, it is just held on with lime-scale / corrosion.
    2. You need to get something "U" shaped behind the four ends of the handles and tap it forward. Madrab has suggested using a partially opened adjustable spanner, which is ideal.
    3. Once you get the handle off, you will need to remove the shroud. This is the chrome plated, circular, metal cone immediately behind the handle. Your's looks as if it may have spanner flats on its back edge (nearest the wall). If so, adjustable spanner again. If no flats, rubber gloves or a "Boa Constrictor" type rubber strap tool to remove.
    4. With the shroud off you'll find a fairly large hexagonal nut forming part of the tap works, close to the rest of the body of the tap. Undo and you'll be able to change the washer. If quarter turn taps there will be no washer and you'll have to change the cartridge.
    All "undoing" means turning anti-clockwise as you look end on from the front.
    Make sure the hot water supply is isolated.
  10. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,783
    Thanks Received:
    1,096
    Country:
    FFS ! If he can't work out how to remove the "Cross Top" He's Fooked !!
  11. jtmk
    jtmk
    16 Aug 2010
    113
    Thanks Received:
    3
    Buckinghamshire
    Country:
    There's not a lot of room behind the tap head and the tiled wall to give it a good wallop with a hammer though! The little bugger is stuck firm at the moment. Any tips or tricks?
  12. jtmk
    jtmk
    16 Aug 2010
    113
    Thanks Received:
    3
    Buckinghamshire
    Country:
    Everyone's gotta start somewhere Terence! I'll go get some skyhooks and tartan paint.
  13. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,783
    Thanks Received:
    1,096
    Country:
    Put your specs on first !!
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
