    Dismiss Notice
Remove emulsion only from door previously painted with oil based paint
Discussion in 'Decorating and Painting' started by DSJC, 29 Nov 2019.
  1. DSJC
    DSJC
    20 Apr 2016
    12
    Thanks Received:
    Cardiff
    Country:
    My glazed back door had a good quality satinwood finish, then last year someone emulsion painted it without any cleaning or other preparation. Predictably that emulsion is now pealing off in places. Any suggestions on how can I remove that emulsion with minimum damage to the glazing sealant and underlying satinwood ? Is there an emulsion only paint stripper? I can’t see sanding all the raised panels and decorative sticking would be practicable.
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    64,349
    Thanks Received:
    3,412
    Battery Park
    Country:
    Cook Islands
    emulsion softens with water. You can try wetting it with washing-up liquid in warm water and rubbing it with a green nylon pan scourer (or white, which is softer). residue in nooks and crannies can be removed with a stiff brush after it has been softened by the initial clean. Don't let it dry or it will harden again.
    you will probably still have a few bits that need a scraper or fine sanding.
    • Thanks Thanks x 1
  4. sparkwright
    sparkwright
    20 Aug 2009
    7,380
    Thanks Received:
    900
    Dorset
    Country:
    Sometimes just applying water, and not use the scourer, can make the emulsion bubble up sufficiently to simply peel it off.
    • Thanks Thanks x 1
  5. opps
    opps
    16 Jun 2006
    4,183
    Thanks Received:
    631
    London
    Country:
    Meths will soften the water based paint.
    A couple of months ago I had to remove badly applied waterbased eggshell from some doors that had previously been painted with oil based paints.
    I sanded the flat sections but the mouldings kept clogging the sand paper. It didn't have any meths to had so I used cellulose gun cleaner. Within seconds of applying the cellulose the waterbased paint started to crack and blister. I then used loads of kitchen paper to remove the gooey mess. The old oil based paint wasn't affected by the cellulose.
    As an aside, I have only ever found one waterbased finish that sands without clogging my abrasives. I am going to stick with oil based wood finishes until I retire/kick the bucket.
    • Thanks Thanks x 1
  6. mattylad
    mattylad
    27 Apr 2008
    7,051
    Thanks Received:
    437
    Country:
    What about sugar soap?
    steam stripper?
  7. opps
    opps
    16 Jun 2006
    4,183
    Thanks Received:
    631
    London
    Country:
    Oh, i forgot to add, every water based finish that I have encountered breaks down when it comes in to contact with the oils in people's skin (and that includes workshop sprayed kitchen cupboard doors). I guess you could just apply olive oil over it and then let it soften it slowly. You will then be able to use a plastic scraper (to remove the paint).
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
