removing a Baxi 105e heat exchanger
21 Mar 2011
South Glamorgan
Hi, can any one help. I have removed the boiler and pressure tested the system to find that one of the heat exchanger seals is leaking and I cannot pull the heat exchanger from the 4 seals that hold it in place.
I have tried to leaver it free with a flat bar but it will not budge is there a retaining bolt or screw and I am stumped. So please help how do I remove the heat exchanger without damage.
Thanks...........Len
You should not be replacing a Heat Exchanger on a gas boiler unless Registered and competent! (I suspect you have forgoton to remove something - but I cannot comment further) Get a RGI to do the job and stay legal!! :wink:
You on about the plate heat exchanger there is 2 screws either side at the front
I am sure that you are talking about the plate hE.
But levering it off with a flat bar is laughable when its held in place.
Even if you now do remove the screws its probably distorted so much that the HE will need to be replaced!
Tony
