Removing a radiator and moving another help please.
17 Jan 2007
Yorkshire
Ive moved a stud wall, and now have radiator pipes in the middle of the room, my plan is to totally remove one of the radiators pipes, by putting a straight run through from the two old valves. The other i plan on moving the valves about 2 foot with new pipe and conceal in the stud wall ready for my towel radiator.
Am i correct in thinking that the above wont cause any problems?
When i drain the system its a combi boiler do i.
Turn power off to boiler,
open drain valve in celler and fit hose to drain
open upstairs rad valves
Drain the system (does this need to be totally?)
Do the work required
Fit towel rad
Fill the system
bleed rads downstairs, then bleed upstairs
Have i missed anything important
Andy
Your first paragraph is not very clear, if you was reading that to a blind man do you think he would understand exactly what it was you are intending to do, if you conceal the pipes in the stud wall how are you going to get to themin the future ???
Right i have the valves and thermostats for 2 radiators in my bathroom now.
I want to remove 1 radiator totally, so i plan to cut them off under the floor and fit some plastic pipe between the pipes.
The second radiators valves and thermostat i plan to cut off under the floor run new pipe through a stud wall and out of the wall using an elbow valve to the towell radiator, I dont want to run pipes out of the floor as they always gather dust, if i ever need to get to the pipes, ill just cut the area away and repair, then replaster and paint.
Is this now easier to understand? the rest of the post remains the same
Andy
now its a bit clearer dont join the two pipes, just cut back as far as you can and cap off, or you will create a byepass for the rest of the system
Thanks for that am i correct in my ideas for the rest of the work? i,e draining the heating system and moving the other pipes.
will push fittings be enough to cap off the pipes?
I would not use push fit they have been known to blow off,
as for the rest of your plan it seems ok
