Removing a radiator
28 Dec 2005
Essex
Hi my first time on this site, I hope someone can help me. I want to move a radiator from one wall to another. I am ok with the mechanics of disconnecting, soldering pipes and reconnecting etc. I am just not sure about draining systems if I have to and what happens when I turn water back on regarding air in the system etc.
I have a modern combi boiler and standard copper pipes, I have looked to see if I have a drain down valve but can't find one, can anyone out there help me?[/code]
Do you know how to vent the radiators?
Do you mean help in locating a drain off cock?
If you don't have such a thing, which would be unusual, then you'll have to choose a rad that's over a floor covering that won't be easily ruined, and be prepared to catch the water from that rad. Start by turning off the rad valves, then after removing the rad you can attach an appropriate fitting and conduct the drain down from there.
If I were you, I'd start by buying a pair of rubber bungs for the cold feed and the vent pipe, and (at least one) radiator tap with integrated drain.
Then, when you've bunged the system and loosed the rad tap, the first lot of dirty water you can catch in a basin before you change to the new tap, and drain neatly with a hosepipe. I think those valves with drains are great, I've got them on all my downstairs rads now.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=11074&ts=31182
BTW a washing machine hose has a screw-on end that fits most radiator taps and so is handy for controlled draining if you really haven't got a drain-off already. You can buy them 3 metres long.
Combi boiler-Ahem :confused: no cold feed/ vent ;)......w/m hose good idea :idea:
