Hi, Hopefully someone out there can help...
We are currently re tiling our bathroom and in the shower cubicle I would like to take the shower unit off the wall to I can tile properly, rather than tiling around it.
The shower is a Triton AS2000XT, I have switched the elec off at the fuse board, taken the front cover off and disconnected the elec supply. I have also switched the water off using the isolator valves on the pipes, but don't know how to disconnect the pipes ?
The water supply comes in from behind the wall and just under the shower unit, through the supplied elbows then into the unit. Reading the manual, there was a little tool thing that is used during installation and they just push in like a press fit fitting ?
Would appreciate some advice on how to do this, i'm sure it is very simple and a 2 min job !
Thanks.
Thanks.
