Removing a socket and moving another - have I sinned?
9 Aug 2006
Lancashire
We have installed an Aga in our kitchen. In order to do so we had to remove one electric socket and relocate another plus a telephone socket. Since our usual electrician is busy working away and we needed to have the room ready for the Aga I did the first part myself. Removing the sockets was straightforward - I lifted the first floor, pulled up the cables and removed the excess. I was able to shorten and re-join one at a nearby junction box so that to all appearances that socket never existed. The second was the socket I want to move about 5 ft to a corner of the kitchen. I simply took the cables that had come up from the wall, pulled both through to the corner and re-joined them temporarily with a 30 amp junction box, leaving the longer piece coiled up for the electrician to use when eventually he turns up to reinstall the socket.
My questions: have I already broken the rules by doing this much myself?
If I continue and reinstate the corner socket, am I also breaking the rules?
The socket will be at worktop level in the corner of the room (about a foot out) with the telephone socket alongside. Any rules against this?
The telephone socket had two cables coming down much like a ring main except that they both came from the same direction. I couldn't pull them up so I cut them as near as possible to the top of the wall then all I did was join them together and take off a single cable, which I fed through new holes alongside the ring main cables to the corner awaiting the arrival of the electrician.
I wonder why the telephone socket had two cables supplying it?
Is telephone cable subject to the same new restrictions?
Grateful for your views!
Yes you have sinned by carrying out notifiable work without using a self crtifying spark or informing Building Control.
Once the plagues of locusts and rats have finished with you, what is left probably will - you may hear a gnashing of teeth about then too..
Worse, if there's a fire , say, and the insurance company detect uncertifed work, the second bang will be the insurance cover going.
holmslaw said:
As it is the christmas season tie together 12 bunches of holly and give your self a thorough thrashing - or let your spark do it for you.
We charge extra for that :wink: :lol: :lol:
