Removing an Antrax/Aladdin Radiator Bleed Valve
21 Feb 2025
I have a half-inch Antrax/Aladdin automatic bleed valve in a towel radiator that needs replacing—either with another Aladdin HV30 automatic valve or a manual. Unfortunately, I don't have a U key to unscrew the valve from the radiator (there are no flats for a spanner, just three holes spaced around the top rim). Is there an easy way to remove the valve without a U key?
