Removing Brick With Cement Mortar
31 Oct 2025
I am looking to remove 2 bricks from a bedroom chimney so I can get more access to get the chimney swept. The bricks seem to have been laid with a cement mortar so it is difficult to get the brick loose. I have tried a hammer and bolster chisel as well as a cold chisel which doesn't seem to make much of an impact. Access is quite tight as the chimney breast is plastered and I am not wanting to remove any more plaster than I need to.
What's the best way to remove the brick and clear the cement mortar?
Stitch it away with a masonry (SDS) drill. 6mm ish bit, lots of holes, then a chisel to break it up
You can cut out mortar joints with a diamond blade in an angle grinder. Widely used when repointing.
A multicutter could also do it. Slow, but you probably only have about one brick to do. I have a demolition saw with TCT teeth, but they are not common.
Is the mortar very hard? If not, even a hammer drill could go through it.
What tools do you have?
As above sds with a 5 or 6mm masonry bit, drilling lots of holes in the masonry joints, close together, then join them up.
If it is a 115mm blade it will only cut to about 32mm though. A brick is 4.5" deep. That is 11.43cm.
Personally, I think the chain drilling makes sense.
I had to to remove a number of bricks like this, I drilled a couple of holes and then sawed through the mortar with a tungsten carbide reciprocating blade. The grinder method will spew material all over room, unless you have extraction.
How hard is the mortar? Will a hand saw cut it, or a block saw with tungsten teeth? Or a masonry blade in a reciprocating saw.
I’d avoid an angle grinder if you can.
It will be quick to cut the mortar, but weeks to clean up the dust.
Stitch drilling will be easier
Invest in a plugging chisel: you'd normally attack the mortar but your joints are so tight I think you'd be best off just sacrificing a brick or 2. Absolutely avoid the angle grinder indoors
Consider fitting an access hatch for future chimney maintenance.
Although most sweeping is done from the fireplace or appliance, are you sweeping it yourself or has a pro sweep asked for this?
