Hi all,
Whilst floor boarding my loft, I noticed that a couple of bricks were loose on the chimney breast in there. I thought it would be best to remove them completely, clean it up and cement them back in, rather than just re point them, mainly because I was worried of fumes escaping from the living room gas fire.
Although the bricks were loose, they still needed chiselling out slightly. Once removed I was surprised to see lots of mortar behind, which I chiselled at to clean up ready for the bricks to be put back in. In doing so, it became apparent that the chimney is lined with clay flue tiles, which I have now accidentally cracked and have also chiselled away some of the mortar between the join of two tiles, exposing the flue vent.
I have three pots on top of my chimney stack, but have only one gas fire utilising the chimney, so I hoped that this was a redundant flue, but I put the fire on and I could feel that the clay flue had heated up a little, proving that it is the flue in use.
In my old house, I had the chimney stack removed professionally from on top of the roof and then, years later, I removed the rest of the chimney breast from the loft to the ground floor and there was no lining at all, just two bricked sections. So this time around, I was naive in thinking it would be similar.
Can this be repaired with fire cement so that I can carry on using my fire without the risk of fumes escaping into my loft?
I would appreciate any advice anybody can offer.
Thanks,
Dandyman
Thanks,
Dandyman
