    Dismiss Notice
Removing Bristan basin mixer tap cartridge
Discussion in 'Plumbing and Central Heating' started by Grandadchris, 19 Sep 2019.
  1. Grandadchris
    Grandadchris
    16 Aug 2019
    5
    Thanks Received:
    Country:
    I am trying to replace the cartridge in our basin Bristan mixer tap. I removed the tap lever and the large nut underneath but found the cartridge would not lift out. I then used pliers to get a better grip but then part of the cartridge came away leaving the bottom part in place (see photos).
    I have tried WD40 and Limescale remover to see if it will losen it but still this bottom part will not move.
    Has anyone got any suggestions? I am trying to lift it out with long nosed pliers. Do I need to rotate it? II could simply try and reassemble the old one, if all else fails, but not sure how the pieces fit together.
  2. Sponsored Links
  3. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    I put a screwdriver in the side and gently lever it over till it breaks the suction on the bottom
    o rings.Bob
    • Like Like x 1
  4. Grandadchris
    Grandadchris
    16 Aug 2019
    5
    Thanks Received:
    Country:
    Bob,
    Thanks for your suggestion. At first it still would not budge. Then I gave it a dose of Limescale remover gel plus WD40 for good measure. Next day it moved then popped out. I have since fitted a new cartridge and all is well.
    Thanks for your help.
    Chris
    • Like Like x 1
Loading...
Share This Page
