I have a blocked drain. There is a rectangular inspection chamber cover (Peter Savage) in the block paving which I need to lift to clear the blockage. The cover is the tray type filled with blocks. It looks like galvanised steel and has probably not been lifted since installation seventeen years ago. Despite removing the blocks to reduce the weight and clearing the gap between frame and tray as far as possible the tray refuses to move. I am now considering removing the whole frame to get at the blockage.
Anyone felt the same frustration or found a better solution?
