Removing debris from downpipe and drains set in concrete
16 Nov 2013
Kent
We've got a (2 year old) UPVC downpipe leaking from the swan at the top. A roofer just told me he is convinced that the downpipe is full to the brim with moss and other debris, and when pushing the downpipe it feels very heavy, so I think he might be right.
The issue now is how about cleaning it out. The roofer said he doesn't work underground, and thinks that a proper job would need to break up the concrete at least around the underground (under-concrete) elbow . Are their any alternatives that might work?
I believe the downpipe is connected to a run of plastic drain pipe that runs with at least two 90 degree bends to the soil stack underneath the lounge which has new laminate flooring down (I saw this drain pipe when I layed the flooring 6month ago...). The only thing I can think of is a drain auger or chemical pipe unblockers.
Actually, this just got sorted. We were able to remove the downpipe and then push down drain augers and a (mains-pressured) hose pipe. At least partially unblocked now.
For future issues I would suggest installing a trap section into the bottom of the downpipe.
to unblock pipes dont ever on anythin use chemicals - just dont.
down pipes typicly discharge into gulleys.
your description of where the rain water pipe flows is a puzzle - are you sayin that it returns under the house - to a soil stack under the lounge?
It runs through the lounge towards and presumably into the soil stack on the far side of the kitchen, and with very little drop.
Can you please explain how that works & what sort of trap is needed?
I have a downpipe that feeds into a partially pipe leading to a soak-away. Lots & lots of leaves here (and some moss) so this downpipe clogs with debris at the bottom and in heavy rain the downpipe fills with water and the gutter overflows.
When I took the downpipe off the other day there was c. 5 inches of muck in the bottom. So a trap to catch all of that sounds like a good idea. However the only traps for rainwater, etc, that I am aware of are this sort of thing, and they are to prevent sewer gas getting back not to catch debris.
I can't find a link to the exact one that I use but something along the line of this ( https://www.guttersupplies.co.uk/products/black-half-round-gutter/68mm-access-pipe/black/ )
If you have a local plumbers merchant or plastic supplier they will have something similar.
Google downpipe leaf/debris gulley
Thanks very much, I had not seen that sort of thing before.
I don't think I can fit one of those now as it involves changing the connection to the soak-away feed. We need to re-do the soak-away (or at least that feed pipe), but that will be a while as the soak-away is too near the house for modern regs, and to make it comply it will need to go under the front yard, which is currently tarmac which needs replacing. But the whole front yard layout needs changing.
Thanks for that. I got confused at first as that looks like it is just a hole in the pipe! Looking at other examples I see that there is a cover on the front but this picture shows it with the cover removed.
You originally referred to a trap but this looks like it just gives access to enable muck to be removed. Is that right?
I had a look online and found this
https://www.freeflush.co.uk/collect...ing-filter-leaf-separator?variant=29003795777
which is supposed to catch leaves, etc, and keep them out of the water.
What about a water butt with mesh shelf half way down and an outlet (always open) running back into the drain?
