Removing dry adhesive from tiles
21 Aug 2007
Ayrshire
I just tiled my floor (first time doing a floor) It was late when i fineshed and just wanted to sit down. There are some spots of adhesive/grout hardened on the tiles. Can someone suggest a good way to remove it.
Soak them in a bucket of water overnight - the stuff will come off as easily as a wh*re's drawers.
________________
Er, oops, sorry - I meant to write "soak", not "some".
Been on the cider again Softus? :wink:
To remove dried on grout you need to use warm water and a scotchbrite pad wrapped around a block of wood. I'm assuming your tiles are glazed - if not, try in an inconspicuous area first to make sure the tile surface doesn't get marked.
