Removing grout
15 Oct 2009
Devon
Is there an easy way to remove the grout between tiles in my shower?
I bought a high tensile steel tool, but the sharp end mounted in rubber keeps falling out if I put any real pressure on it?
Stanley knife. Cut into both edges of grout line separately, then it hacks out easily. I also use an electrical test screwdriver to scrape it out. You will also need elbow grease. How much grout you remove depends on whether you are removing it to replace a tile or just re-grout dirty grout. I use a folded edge of sandpaper for the latter.
