Removing Head Gear On My Mixer Tap
31 Dec 2009
My kitchen mixer tap is dripping and driving everyone in the house nuts. First problem is working out how to get into it. There's no H and C indicators covering screws, or anything obvious that I can see. Any suggestions?
Also, can anyone identify the make of this tap? It's very similar to one made by Abode but that's all I know. Also also, will it likely have rubber or ceramic washers?
Thanks for any help. Photo attached
If you haven't any grub screws round the first collar below the handle then the handles will just pull off.
The first collar is part of the handle so will seperate between the upper collar and shroud.
Thanks for the quick reply. So, in general, how hard do you need to pull to get them off? I'm guessing quite hard!
Just thought I'd follow up now that the job's done. The handles did indeed just pull off - or at least with a bit of persuasion from a screwdriver. The shroud actually screwed off as well. Maybe if I'd known that, screwing the shrouds off would possibly have forced off the handles.
Turns out it had those ceramic cartridge things not rubber washers. I bought a replacement pair from BandQ, but I have noticed something strange. When I removed the left hand tap (the hot one) it had a blue "washer" and so did the right hand one. I've installed the new ones, red left, blue right, and the taps behave strangely. The left opens clockwise and the right opens anti-clockwise. I'm guessing that these these cartridges are more designed for lever taps. That's probably why they perviously had blue on both left and right. Does that make sense?
Anyway, they work fine.
