Removing inside vent cover for cleaning
27 Jan 2019
Hi all hope someone can help
Have attached pic of vent, no obvious screws have tried "popping" it out have tried turning to the right and then left nothing almost seems wedged in.
Have also tried to pop the cover out with a flat screwdriver but not really budging (is a tiny little bit but the cover seems quite fragile and don't want to force it)
Basically it is disgusting under the cover and needs a good clean, recently moved into property and could not figure out why so much dust in the air think this is why.
What is the correct way these should be opened?
thanks for any help appreciated
isnt coming out! have already broken one part of the middle trying to pop it out again and when levering the edges the plastic feels very very weak
mmmm
i cant even get the outer ring off think that is glued in!
thanks for your reply
Is it just stuck with emulsion paint? Try running a blade round it. If it is still tight try tapping it gently all round then applying upward pressure at the same time as turning it. I can't think why anyone would need to glue it in place.
thanks but still no good
very close to it snapping now so better leave it as not my property :)
thanks all
