Removing Laminate flooring
25 Mar 2005
Hi ,
Can anyone give me some advise on the best way to lift Laminate flooring -without damaging it if possible.
Also are there any special tools or tool to make the job easier?
Thank you
if its unclickable[and unglued]then be prepaired for 10 to 20% waste if re instaled in the same room
or 30 to 40% wastage if a different location :cry:
I dont know what system it is as it was already laid before we moved in.
Therefore could you please describe the usual tried and tested methods .
Also is there a technique for lifting click together type that I should know about?
no seceret after removing the edging or skirting lift the edge and iff it breaks its nackerd if it unclips it may be reusable
if theres a specific area you need to access please ask again :wink:
