- Joined
- 2 Mar 2006
- Messages
- 59
- Reaction score
- 2
- Country
I'm want to instal new iron railings to the front wall built around 1885 and need to remove the old iron stubs from the coping stones. The stones are 20" x 30 " x 4". The old railings were cut off level and are 3/4" round set in lead in a 1" hole. The hole does not go all the way through the stone so I can't just knock them out ( gently). I've tried picking out the lead ( laborious), heating with a blowtorch ( the lead doesn't soften much and the stone spits) to no effect. There's around 40 to do. My latest idea is to drill a pilot hole and insert a screw so I can use a puller....I may have to use a blowtorch/acetylene to soften the lead but I'm very wary of cracking the stones...they are irreplaceable. Alternatively, drill pilot holes and use progressively bigger bits until the iron is drilled out....the lead should then come out easily enough. Any experience/advice ?What sort of bits would I need if I drill ?
