Hi guys,
Have just taken the old tiled splashback off the walls in my kitchen. Came off reasonable easy thankfully.
I have scraped all of the loose adhesive from the wall where the tiles were but do I need to get every last bit off or will it be ok as long as all of the loose stuff is off?
Under the old adhesive is skim which in turn is on the plasterboard - should I use a primer on the skim / old adhesive before putting the new adhesive on or just go for it as is?
Finally - the old splashback was only two 10cm tiles tall - with the new tiles I intend to go all of the way up to the bottom of the wall units. Any tiles above where the old ones were will be on painted skim... again will this need priming?
Thanks in advance for your help.
