Removing sockets from skirting boards
23 Sep 2009
Middlesex
Someone has asked me to help them move their socket outlets out of the skirting boards as they've been told this needs to be done before they can address a damp issue they have, although as yet I'm not sure whether someone's just unaware that regulations aren't retrospective or they do in fact need moving to do the remedials.
Anyhoo, having not encountered s/o in skirtings before what am I likely to find and need to do apart from probably extending the cables and making good the skirting?
I guess the skirtings will be getting replaced as well.
You've answered your own question, you'll find the cables will either need to be extended or it could be worth considering replacing them.
It's a Victorian apartment and from memory the skirtings are at least 12" high, possibly more, so I'm not sure whether they're going to be replaced or not.
Is the cable likely to be routed behind the skirting or under the floorboards?
The cable is likely to be under the floorboards.
There may or may not be some slack cable.
About half way up this type of skirting board there is often a batten behind, fixed to the brickwork - so this will need to be drilled through to get the cable up the wall.
Adding extra sockets may help to solve the problem of extending cables.
