removing the drum on a mixer
5 Nov 2009
Lancashire
been given a belle mini mix 130 cement mixer the drum is sliping due to worn teeth but i can not get the drum off ,,on this model it looks like it pulls off and not screwd off but i can not find any thing about removel ,,,, any one done one
On my 130 l baby belle, you grasp the top and turn it to the LEFT. Its tight, as the threads will have rusted. You could try tying a loop around the drum as tightly as possible with a long end (4'?). Wrap the long end around a bit of 4 X 2 say 3' long. Put the free end of the wood on the left of the knot on the drum and rotate the wood anti clockwise, the rope should lock up and turn the drum.
Frank
i will give that a try ,, at the moment i have wedged two cold chisels between the mixer and the drum and its not moved
Something in my water tells me that it's the 150 drum that's threaded, and the 130 has a roll pin through the shaft?
I just can't remember....the 130 is the one with the plastic ring gear, isn't it?
John :)
yes the one i have is plastic ring gear,,, and there is a clip with a pin that seems to secure the drum,, this pin just came out no problem,, ive now had a rope and 3x2 hiting with 10llb sledge,,, no joy
