Renault Espace
19 Apr 2009
Yorkshire
At present I am in the process of TRYING to remove a power steering rack from a 1995 2.2tdi Renault Espace, Could any one tell me which side of the vehicle that you extract it from? As I can not get to the hydraulic hoses due to the tight working area, and do you have to remove the mounting brackets before you remove the whole rack?
You'll need to slide it out the drivers side wheel arch. Sounds simple, but this is awkward, and requires pulling, levering and twisting the steering rack. Levering the brake servo bracket about is required, but be careful that you don't use too much force. You will have to twist the steering rack anticlockwise to lever it out, taking off some of the underseal on the footwell off with the splined shaft. Also make sure the power steering pump pipe is fed through as you remove the rack.
