renault traffic dci140 2004 van
3 Jan 2010
Sussex
HI, HAS ANYONE HAD ABS WARNING LIGHT / SERVICE LIGHTS / BRAKE LIGHTS ON ALL THE TIME WHEN IGNITION IS TURNED ON AND RUNNING, ?, I HAVE HAD ABS SENSORS TESTED AT RENAULT GARAGE. OK. WOULD THIS BE LEADING TO THE ECU. AS THE MAIN PROBLEM. NEED TO RECTIFY FOR AN MOT. FAILURE.. WOULD AN REPAIRED ECU. UNIT BE THE NEXT SOLUTION???. CHEERS.
Its more than likely the pump .
Did they change the sensors or clean them? Sometime the connections break down in them!
THEY CHANGED FRONT DRIVERS SENSOR, AND TESTED ALL OTHERS. OK
HEATER COIL LIGHT COMES ON ALSO AFTER ENGINE IS RUNNING FOR A WHILE. OTHER THAN THIS THE VAN RUNS PERFECT ALL THE TIME, ANY IDEAS??. CHEERS.
