Renault Trific, weak revs
2 Sep 2010
Yorkshire
Hi guys
My van wouldn't rev when cold, so I fitted a new mass air flow meter and it made a big difference, but she's stil reving a little flat, but when i dip the clutch she revs perfectly,
Might be best to get it plugged in, to read the fault codes.
the fault was air flow meter nothing els but its annoying pulling into trafic and she reacts a bit slow, but apart from that its fine, im just stuck as to why dipping the clutch would make it rev better.
the fault was air flow meter nothing els but its annoying pulling into trafic and she reacts a bit slow, but apart from that its fine, im just stuck as to why dipping the clutch would make it rev properly.
It's to do with load, there's no load when dipping the clutch.
Diesels are all electronic now.
I understand what you mean about load but when its stationary the revs are bit flat, then dip the clutch and it revs perfectly.
