Render directly to ply good idea or not
8 Mar 2007
Hi
Having some work done at a property which needs rendering (outside ),any way,renderer wants to put up some ply put some mesh on the ply and then render.DOes not seem right to me is this a acceptable application method
Hi
This is all new build he wants to use wire mesh to hold render I am worried about expansion and cracking therefore failure.only reason for render is to match in there is no blocks work there
If you use good quality ply and put building paper on it double line it with s/steel expanding metal and then scratch coat it then float coat ,No problems .. :wink:
