rendering finepoints
28 Apr 2009
Kent
what is the minimum depth of a float coat? also i normally use sbr as an admix instead waterproofers as it makes the render sticky but does this react with lime? and one more thing is it wrong to prime the wall with sbr with scutching for mechanical key. any help appreciated
Half inch or the damp can weep through, It should tell you coat thickness on the tub, if not then find the makers website and read their speck sheet.
