I recently replaced my garage door with a roller, I'm now left with exposed brickwork where the wooden doorframe was. I considered using upvc to cover the brick but its uneven (some of the bricks stick out around 20mm) and so I reckon it would need boxed out with wood before covering with pvc. In addition I would have to trim back the existing roughcast on the outside wall as it currently overhangs the brickwork by approx 20mm (this previously overlapped the wooden doorframe).
So I was wondering if I should try roughcast instead, was thinking I could use wooden battens on either side of the opening to get the edges right, not sure if this is a good idea or if there is a better a solution available?
Also the bottom of one side of the doorframe is exposed brick with no roughcast so roughcasting there might not work....
View media item 90976
View media item 90977
View media item 90978
