i have removed a tile hung section under a window external and screwed external plywood to studwork.i would like to render the bay.what would be my best way thanks.
we have rendered a loads of these .you need to fix some EML onto the ply covering it all making sure the EML is tight and joints tied with wire
then you mix a 3 to 1 sand and cement with waterproofer and plasticiser
and apply a scratch coat let this harden for two days then dampen down and apply your finish coat
