You just need to paper and wire it, scratch and render it.
Make sure the wood is BONE dry before you use sand and cement, as if its wet and dries out underneath the render, even with wire on it, it could crack.
ditto
ditto
cover it in rendalath
maybe so but i think it would be best for the jobYou just need to paper and wire it, scratch and render it.
ditto
Either, although the cost would lead me away from rendalath.
ditto
isnt this the same as rendalath? Double paper backing with square lathing.As you can see there are many ways to do it. i would paper wire and render it, other people reccomend other ways, so its up to you!
lol, it says rendalath in the sheets though, sometimes known as k-lathI just call it paper and wire, if i said to the guy who taught me render lath etc...he would look at me as if i was a knob. if i said paper and wire he'd understand.....
As you say there is more than one way to do the job but for a little extra i would rwther rlath it, make sure you overlap the sheets by at least 100mm and hammer lots of nails in and use corner/angle beads on all your corners. This will stop any cracking and will provide a suitable backing for coating on
Not really, big difference in price for a start :0)
