When ever I've seen people do rendering they have put a scratch coat on and left to dry out before putting on a fiinish coat and then leaving this coat to dry out before other work is carried out, i.e textured finish or painting.
A friend has had his extension re-rendered which was done as described above. now the workmen has come up unexpectantly when nobody was home and more or less took off the bottom half of the render right back to the brickwork, judging by the waste render left in the skip. They then appeared to have re-rendered all three coats in one morning - that is a scratch coat, finish coat and texture!!
My two question is: There must be a reason for rendering in stages so if you can do this application in one go then why do people do it over time?
Secondly, the new render is clearly much ligher in colour (almost white) so does anyone have an idea what they have done?[/img]
