Repair gate post
22 Aug 2005
Staffordshire
I have a wooden gate attached to wooden gate posts which are themselves attached to concrete block garden wall. Problem is the gate post is rotting/eroded where it meets the concrete paved patio.ie from pavement up about 3inches. Any ideas about how to repair this in situ? I think the post was originally planted in the concrete patio.
All suggestions gratefully received. :confused:
I have my side gates hung from 3" fence posts either side of the drive.
The post against the house wall got damaged so I refitted it using a couple of frame fixings like these.
It depends whether the block wall will take the strain of the gate swinging on it.
i was thinking along simmilar lines dewy
although if possible cut off the rotten bottom off the post at an angle part way accross its width from the wall to finnish it off neatly
if it is placed near the ground leave a gap between the ground and post to stop rot
Right BA
I had to repair mine when British gas did some work and PULLED the gate that should have been Pushed to open.
They pulled the hinges off the post then denied they had done it despite being the only ones to have opened the gate which was always locked but had been unlocked to allow them to get in to do the work.
The only reason the opposite post is still standing is because it hadnt been fitted into the ground but had been nailed to the gatepost nextdoor.
Also cut the bottom of the post in a angle (wedge shape to the gate) to allow rain dripping off instead soaking underneath the post.
