One of the gas hob ignitors has stopped working. Clever clogs here thought it’d be a good idea to find the serial number for the gas hob which would be located underneath the unit. I prised up the hob from the worktop and didn’t realise there were clips at the front holding it in. They’ve lifted and broken off a bit of the laminate. Each damage is about 10x15mm. It’ll partially covered by the hob when replaced but still visible and water will definitely get in from cooking or cleaning.
Has anyone successfully repaired a laminate worktop?
