repairing plaster skim for tiling?
21 Dec 2017
Hi all,
I recently put up a some tiles on a wall at the end of my bath.
It's a newly plastered wall done by a plasterer and I used acrylic primer before tiling with cement based adhesive.
For various reasons <sigh> I have to take them off and redo it. I've knocked one of the tiles off and it's taken the plaster skim with it. I assume the same will happen with the rest.
Not sure what kind of backing plaster is underneath. Grey and sort of gritty. So before I re-tile this I guess I have to re-skim this bit of the wall?
What's the best stuff to use for this? Do I need to reskim it with multifinish or can I just use e.g. thistle one coat? Or could I just level it up with a skim of tile adhesive?
Cheers!
Backer board or lime render are the best backgrounds for wet wall tiling - a skim finish is definitely not needed, neither is the use of any gypsum plaster.
The grit is good stuff if the plasterer uses it properly?
What state the wall will be in when the tiles are off will only be revealed when they are off. Perhaps, post a pic?
You could soak/immerse the tiles for 24hrs and then probably scrape off any residue, and re-use the tiles.
Thanks for the response.
This wall is at one end of the bath - the other 2 are new stud walls and I have used STS shower boards (wedi type stuff) as their covering. Since this plastered wall is at the opposite end to the shower and it's a second bathroom that likely wont see much use anyway, I'm reasonably comfortable with it being plaster/gypsum substrate etc.
I'll put up a pic once I've knocked off the rest of the tiles. I do struggle to see how putting a new skim of plaster over the top of whatever is underneath will really aid matters. If I stabilise it and drop the suction with some more acrylic primer then surely It's OK to just tile over the top?
Since it's powder/cement based adhesive I don't think soaking the tiles will do much? Anyway I will be putting different tiles in their place.
