I've got a 16 year old house with an open vented system and two zone valves (HW and CH).
It all works fine except the AAV in the airing cupboard is leaking water. I've put a ball of PTFE in the cap and that's blocked it for now - and perhaps will be ok till the boiler needs replacing or it's next drained down.
Seeing as so many AAVs leak, I might replace it with a manual bleed valve. Currently, there is a soldered coupling with the AAV screwed in. I want to screw a service valve there instead with the new vent / bleed valve on top.
First question ... is it so that the high point bleed valve is really only useful when refilling the system ?
The second and last question is ... can people suggest the best combination of components to use ie service valve and bleed valve / vent so it isn't unnecessarily tall ... ? (I'm not sure a radiator bleed valve would be ideal, but if anyone else knows better, I'd be interested to hear.)
I look forward to all suggestions ...
