Hi - what a great forum!
I want to replace the wiring in my loft as I need to get some insulation up there. I plan to get the house rewired within a couple of years but can't take going on uninsulated till then.
The loft is about 40 square metres, theres just 1 lighting circuit and no ring main or other cables running up there, and the joists are 100mm high and only a few have notches in already. None are drilled and most of the wiring is just chucked over the joists. There's not enough give in some of the wiring to get insulation underneath safely, and I'd like to put some boards down once I've laid insulation below the wiring.
I'm familiar with the circuit and happy to follow all the same routes as are there now, but don't know whether I should notch and plate or drill to feed the replacement cables round the loft. I can pick up the incoming supply at an existing junction right near the loft hatch so don't feel inclined to pull a new feed all the way from the board.
I think it might be a good idea to replace the switch runs and hardware as the existing switch backboxes are substandard, but wouldn't want to tackle the two way landing/hall wiring yet as I'd have to carve up half the house.
I'd really appreciate some advice, on the joists in particular - thanks
